lowering the rear end on my 1949 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2011, 03:05 PM
I have a 1949 chevy pickup with a 1969 nova rear end. the rear end is mounted on top of the leaf springs. i would like to lower my rear end 4" but the saddle on the rear end is welded to the axle centering kit. this is just a plate use to center a late model rear end under my 1949 pickup. it move the axle back 1 1/2" according to the Brothers catalog. i think i will have to cut the welds off and put the lowering block in between the saddle and the centering block. if anyone have any suggestion please help.
Old 08-07-2011, 06:11 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
so can you put a block between the spring mount and the centering kit? that's how we lowered the rear in my buddies 40 coupe
Old 08-07-2011, 10:20 PM
bigdog7373's Avatar
Of course it's fast
You can use blocks or shackles.
Old 08-08-2011, 09:02 AM
dinger's Avatar
Can you pull out a leaf or 3?
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 08-08-2011, 10:18 AM
jalopy45's Avatar
Two choices, easiest is to redrill spacer block so the pin hole is offset 1 1.1/2" or replace springs with center bolt set back 1 1/2", the cars have the same problem up to '54 with the closed driveshaft.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 08-09-2011, 05:37 AM
[QUOTE=jalopy45] Two choices, easiest is to redrill spacer block so the pin hole is offset 1 1.1/2" or replace springs with center bolt set back 1 1/2", the cars have the same problem up to '54 with the closed driveshaft. [/QUOTE
so can i just remove the centering plate from the saddle on the rear end (welded to it) and put the lowering block in between the centering plate and the saddle. like i said the centerin plate offset the rear end 1 1/2 inches, bu it is welded to the saddle.
Old 08-09-2011, 02:04 PM
Check out Item #:
91043320 at speedway motors it's an adjustable lowering block. It may work for what you are trying to do.
1949 chevy 3100 pickup alv55 Introduce Yourself 1 09-22-2010 03:30 PM
1949 chevy pickup cruiser 49 chevy Introduce Yourself 5 03-19-2007 09:03 AM
1949 chevy pickup sumdaymyownshop General Rodding Tech 3 02-14-2005 08:20 AM
1949 chevy 5 window pickup shrades General Rodding Tech 2 08-04-2004 07:11 PM
Where is the serial # on the 1949 chevy pickup 49dream Transmission - Rearend 2 08-03-2004 10:13 AM
