Lowering rearend on 37 Olds - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2004, 04:00 PM
New Member
Is there any bolt on leaf springs that will lower the rear-end on my 37 Oldsmobile?
Old 06-16-2004, 11:47 AM
Contact Eaton Spring. They can build springs to whatever configuration, spring rate and support mounting that you desire. You can do a lot of this thru their web site eatonspring.com
Good Luck.
Old 06-17-2004, 06:32 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Might check www.chassisengineeringinc.com they have a universal leaf spring application
Old 06-17-2004, 07:55 AM
Rick 5150 69's Avatar
Used a set of `58 / 59 chevy pckup springs on my 33 chevy, if your doing on the budget, just us a sidewinder and narrow down the spring eyes to 1 and three quarter from two inch and use teflon bushings in the rear, `58/59 pckup springs are almost flat, used only 4 leafs no lowering blocks, puts the tire up in the fender. Rick
