lowering springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2004, 12:28 AM
montea's Avatar
tryn to learn
lowering springs
will 1 or 2 inch spring drop affect the alignment on my car? 82 grand prix
also how far could i lower my car before i would need to change the shocks on it?
Old 04-26-2004, 12:38 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Re: lowering springs
You won't know until you lower it.
Call the mfg of the lowering parts to find out what all you will need.
Old 04-26-2004, 03:09 AM
malc's Avatar
Living At The Speed Of Life
Caused my Camaro front wheels to lean in at the top, and toe
outwards.
Any changes should be checked
Old 04-26-2004, 04:31 AM
aka Duke of URL
Arrow Re: lowering springs
...will 1 or 2 inch spring drop affect the alignment on my car? 82 grand prix
Yes...But a good alignment tech will be able to allow for it. You have control arms and is much easier to work with than a strut front suspension.
...also how far could i lower my car before i would need to change the shocks on it?
Once lowered, you will have to measure suspension travel and then compare it to the internal stop of the origional shock. If the shock bottoms on it's internal stop before the suspension hits it's stop, damage will ensue. You need to find a shock that will be in mid-travel as the car sits with its' new trim level.
On some applications it is better to go with a drop spindle, but two inches shouldn't be that much of a problem.
