Lowering Springs AND drop Spindles?? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 11-03-2004, 05:16 PM
Redoing a 68 Covertible Camaro. I purchased Hotchkis lowering Springs (2") before reading the post recommending using spindles instead. I'm using BAER track, which have a 13" rotors and Heidts narrowerd tubular A Arms and will eventually go with 17s on the front.
I'm having problems knowing how all this stuff will fit together. Does anyone know if I have to put on lowering spindles as well? Or should I wait to see the finished product/camber/geometry?
Thanks!
Haven't bought the A arms yet, any recommendations would help also. Global west? Detroit?
Thanks again
Old 11-11-2004, 11:43 PM
lowdown99's Avatar
your only problem would be the back spacing on the 17s do some measuring and youll be fine, i lower everything!
