Lowering springs or dropped spindles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2004, 08:34 PM
ComingApart's Avatar
If I wanted to drop the front of a '79 Chevy truck, say 3" inches, would it be worth the extra money to go with new spindles, as opposed to lowering springs?
Whats the advantage of spindles to springs?
As far as the rear, whats the best way to lower a leaf spring setup? Looking for around 5 inches of drop.
Thanks for any help.
Old 03-21-2004, 08:45 PM
poncho62's Avatar
Wiki Edits: 5
Dropped spindles are always preferred over springs. They don't throw out the geometry of the front suspension.
Rear, use lowering blocks.
Old 03-21-2004, 08:54 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
If you're going with the light 500 Caddy engine then you won't need to change the springs.
I would use the spindles, you would have to take everything apart anyway to cut or put shorter springs in anyway.
I think a flip kit that puts the leaf springs under the axle instead of on top, would work good for getting a 5" drop.
Get a Truckin magazine and it will have all the different kits in there.
Have fun with the project.
Old 03-26-2004, 01:33 PM
Spindles don't change your ride quality at all...Shorter springs have stiffer rates, and will stiffen your ride...
