Lowering Springs - Lessons Learned - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2013, 05:07 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I wanted to post this so ya'll might benefit from my experience. I used 5" CPP drop springs on my '65 C10 SWB Stepside Pickup. The ride was like a big ole Buick and the springs were so light weight that hauling anything of significant weight in my truck wasn't possible.
So I replaced the rear springs with CPP 4" drop Heavy Duty Springs. Much better ride and since they are heavy duty I can now haul more than just a couple hundred pounds of stuff The new springs look very similar to the OEM springs that were originally on the truck, just a couple less coils and shorter overall height.
4" Heavy Duty Drop Springs are on the left, CPP P/N 603-4HD, 5" Drop Springs are on the right, CPP P/N 603-5
The Following User Says Thank You to lakeroadster For This Useful Post:
sbutler (06-06-2013)
Old 05-30-2013, 05:14 PM
Banned
I have blocks in mine now 2.5" lowering blocks, that are below the scrb line ,so that will change or bigger wheel..
but I might like your old springs, how far was the rear from the frame rail with them..
I have air springs(the type drag racers to preload one side) for when I'l haul anything
Old 05-30-2013, 06:32 PM
About 3-1/2" clearance, axle tube to frame. I am running altered aftermarket snubbers and with the 5" drop coils had about 3" clearance to the axle tube. The spring rate on the 5" drop coils is so minimal that the truck would bottom out on the snubbers when going over slight bumps and dips on the road.
Old 05-30-2013, 06:38 PM
Banned
then they most likely are the same as the jeep springs people install
hell cpp's might just be those reboxed
Old 05-30-2013, 10:46 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
They look a lot like the Jeep springs I'm using for my 65.
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
lessons learned from first paint job bigsarg1 Body - Exterior 27 08-11-2007 09:29 PM
lessons learned from first paint job part II bigsarg1 Body - Exterior 9 08-11-2007 03:22 PM
My first compressor piping/painting experience - lessons learned and questions! mpaq Body - Exterior 17 07-27-2007 01:46 PM
Lowering springs Longboard Suspension - Brakes - Steering 32 02-26-2006 06:20 AM
Hard lessons being learned here... please help Cracker Red Body - Exterior 2 12-31-2004 05:21 PM
