hey I got a small question I have a 1985 gmc jimmy with a 350 sb my question is .....I have a 3" drop springs that came with the truck when I bought it it also came with 3" lowering blocks for the rear will i be able to install the front springs without having to worry about big change to camber/toe in toe out...if i have it correct. any input will help.
You will have to re-align the front-end after you install the lowered springs. Thats if it will still be able to allign....3 inch drop using a spring is a lot.....
Drop spindles is the only way you could lower the front with out changing the alignment or camber/toe...... |
