Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lowering your top
Old 05-17-2007, 06:39 AM
hammered 51 hammered 51 is offline
lowering your top
its not that hard as long as you take your time and measure,measure,measure. most of the time you will need to legnthen and make it wider,also as the top gets longer the more the drop is, doors are the hardest to do and the glass, get a book, HOW TO CHOP TOPS by tex smith and there are examples on doing this in this book , hope this helps, also if you have a extra top the job goes easier with the peices needed for filling where needed, make shure you cross brace before cutting the top. you can start out with about a 2 1/2 chop ,look and if more is wanted do more.
