lq4 with 700r4 tv cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2013, 06:45 PM
I just put a lq4 6.0 in a 53 chevy pickup. The problem is I had a just rebuilt 700r4 and wanted to use it. No problem adapters available for flywheel. The problem is the truck manifold. There is not a straight shot to the bell crank adapter. From what I've researched u need to be at parallel pull at 25% throttle opening. Using the truck manifold the fuel rail brackets are in the way. Has anybody ever done this swap using the 700 and if so what did u do for a tv cable bracket while still achieving the correct angle and radius on the pull. Sure need some input. Just how important is the parallel thing. Thanks Jesse
Old 01-15-2013, 05:49 AM
SSedan64's Avatar
Some Info & Pics here >> 700R4 Throttle Valve Cable Adjustment Instructions
TV cable geometry & adjustment is very critical.
The TV pressure rise needs to be a little ahead of engine torque.
700R4 Tv cable RatRodDick Transmission - Rearend 1 09-14-2012 12:52 PM
700r4 Tv Cable Custom10 Transmission - Rearend 17 05-14-2010 04:35 AM
700r4 TV cable? runn141 Transmission - Rearend 1 02-09-2009 12:43 AM
700r4 tv cable toolman76usa Transmission - Rearend 3 07-30-2007 02:00 PM
700r4 tv cable ? novaman30274 Transmission - Rearend 2 02-23-2007 05:12 PM
