LQ4 or L76 6.0L GM Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2014, 09:57 PM
Which engine is better for making 500HP out of and what are the pros cons of each?
I have a complete stock LQ4 engine, LS3 intake w/90mm throttle body, LS3 exhaust manifolds (longer version). I am debating wether I go with an L76 engine or just buy L92/LS3 heads for my LQ4...
Old 06-10-2014, 06:49 AM
Last journal entry: Still running strong
Isn't one an aluminum block an the other iron? I don't remember. But I've read that the aluminum block can't be rebored because the steel sleeve is so thin, that is if there was any cylinder damage now or in the future.
Old 06-10-2014, 07:05 AM
Really need more info here... What is it going in? Whats the intended purpose other than 500 HP? Cruise, strip, track?
L76 is alu, LQ4 is an iron truck engine. The weight diffrence is 65lbs. Power is in the heads and the L92 can flow up to 550HP according to CarCraft and AFAIK the L76 has the updated l92 heads. If this motor is going an vehicle where handling is important than loosing 65LBS over the front Axle may be beneficial, if its going in a truck with stock suspension then maybe the weight inst as important.
Old 06-10-2014, 08:31 AM
vinniekq2's Avatar
The LS-3 heads will be what you end up with eventually(or better) Look at the ZO-6 427 and the heads they use to make 505 horse power?
Old 06-10-2014, 09:07 AM
The engime is the LS7. To run the LS7 heads you need to run the larger 4.125" bore, wont work on the 4.0" bore 6.0's.
L92, L76 and LS3 heads are pretty muc the same head, differnt valves, they are designed for a 4" bore and larger.
CPP sells a 525hp 6.2L crate engine using the L92/LS3 head.
peace
PAuly
Old 06-10-2014, 09:42 AM
The motor is going in my 1936 Chev and will be used to cruise, race occasionally.
The L76 has the VVT setup, will this hinder me in making 500HP at all?
Old 06-11-2014, 05:14 AM
It can be removed. The lifters dont take rpm like the non AFM engines do.
Example of this is the 400hp Camaro L99 with its 6200rpm redline and the 426 hp 6.2 LS3 and its 6600rpm redline. L99 has VVT/AFM the LS3 doesnt.
GEN 5 LT1/LT4 have the full redline with a redesign in the GEN 5 engines.
GEN 3 and 4 head comparison Carcraft
GM Gen III V-8 Cylinder Head Comparison - Car Craft Magazine
AFM/VVT delete kit
Displacement on demand / active fuel management delete kit DOD AFM
PCM recalibration will bring all your mods together.
peace
Hog
Old 06-11-2014, 05:57 AM
I finally found the link to an article that compares all the GEN 3 and GEN 4 engines.
Performance Chevy LS Engine Comparison - Chevy High Performance Magazine - View All Page
peace
Hog
Old 11-23-2014, 08:56 AM
Thanks Hogg. I ended up selling my LQ4 (kind of regret it) and buying an LY6, 6.0L iron truck block, with 823 LS3 heads and VVT. I have LS7 ZO6 exhaust manifolds and LS3 intake manifold with the stock 92mm? throttle body, now all I need is a decent cam for this setup.
Old 11-24-2014, 10:27 AM
Good stuff, sounds like you will have a fun combo there for sure.
Those GEN 4 LS7 exhaust manifolds have some excellent engineering in them for stock manifolds.
peace
Hog
GM LQ4 decoding jeepers creepers Engine 6 03-01-2013 03:59 PM
Lq4 Cam And Pistions Need Help. novacrazy2007 Engine 3 11-10-2011 12:34 AM
350 to LQ4? bill plise Transmission - Rearend 4 04-18-2011 08:00 AM
LS vs LQ4 william r plise Engine 1 12-13-2008 02:26 PM
LS1 (LQ4) engine swap Bill Ford Engine 0 07-04-2005 09:35 AM
