Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - LS 2006 5.3 Wiring harness
Old 11-30-2012, 11:46 PM
pshell pshell is offline
Found some pictures. The harness is not in split loom, so it looks unfinished. I wanted to drive it around for a while before I put it back into the split loom.
Showing computer mounting:
I also used the late model radiator and pressure tank. The following pictures show how I modified the core support to do it:
Those brackets are from the stock truck, I flipped them over and swapped sides. I test fitted the radiator then welded them on.
I think you'll find it's been a constant evolution with these trucks. Things just kind of evolved and the placement of components is close if not the same.
Hope it all helps.
The Following User Says Thank You to pshell For This Useful Post:
123pugsy (12-01-2012)
