LS engine dimensions help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 08:01 PM
iceman36's Avatar
HI
Iím boxing in the frame of my 36 Ford Truck and working on the design for the X member. So I need to find some information on engine dimensions.
I plan on using an LS1 style engine.
I have a foam mockup 4L60E Trans and 350 engine, so I know the Trans size but not the LS size.
Q: does anyone know what the block size would be, from Trans mounting surface to the front of the block only not pulleys or pump for the LS.
Then I can allow for the differences between the LS and the 350 to position the Trans in the X member without being too close to the Radiator.
The Trans mount will be temporary until I can get a real LS and Trans.
Mike
Old 08-05-2010, 07:53 AM
LsHeaven's Avatar
LS7 Measurement
Mike,
The LS7 is 20" from Bell Housing flange to the front machined surface of the block.
This measurement is NOT including any accessories or even the crank snout and harmonic balancer, but the machined surface of where the water pump mounts.
I hope this is helpful.
If you need any other measurement, feel free to call me at 214.585.1692.
Peace,
Rob
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
LS engine in '57 Chevy Suburban wave1957 Engine 1 02-25-2008 03:42 AM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
sbc engine dimensions adivito Engine 3 03-23-2005 02:47 PM
Engine dimensions & weights wvrodder Engine 1 12-06-2002 10:01 AM
