Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ls Engine Swap To C10
Old 10-12-2012, 04:53 PM
EagleMark's Avatar
EagleMark EagleMark is offline
GearHead-EFI.com
You can use the harness that came on the truck and save big bucks. Don't need the fuse block but some are underhood and very handy. Most of these harness are installed on engine and trans before they are installed so they come out easy, just a few extra wires need to be cut or relocated. Yes you do need the OBDII connector or you'll never be able to read codes or re-flash the PCM.
