Ls Engine Swap To C10 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 07-31-2012, 02:23 PM
hi guys,
i might get my hands on a 6.2 with tranny included out of a 2007 and up gmc denali
engine would be going to an 84 chevy c10, also would the stock engine harness fit and work in truck? am also getting the ecm, fuse box, radiator, and electric fans and i would like to know what parts would i need in order to complete the swap...
thanks in advance...
Old 07-31-2012, 02:38 PM
bigdog7373's Avatar
Of course it's fast
You need everything engine related. Everything. Accessories too since sbc ones won't fit. There's a lot of threads about lsx swaps if you search.
Old 07-31-2012, 03:02 PM
but would i need fuse box, and stock harness? i can pretty much get everything from the truck that is why am looking for a list of parts i would need from the truck and what i need to buy aftermarket like motor mounts etc...
Old 07-31-2012, 04:15 PM
bigdog7373's Avatar
Of course it's fast
62 Impala LS1-6 swap
LS1 Swap
5.3 ls motor swap in a 72 chevy c10
ls1 swap for a 2001 gmc sonoma
Search, my friend. Then read mucho.
Old 08-01-2012, 01:03 PM
Would i need the obd2 connection from the truck so i can later tune the engine once its swapped?
Old 08-01-2012, 01:10 PM
bigdog7373's Avatar
Of course it's fast
Hmmm that's a good question. I say yes because it's better to have it and not need it, than to need it and not have it
Old 08-01-2012, 01:37 PM
Wiki Edits: 31
Just get a conversion wiring harness. I think Even GM sells 1 as they sell a drop in LS retrofit crate engine. You can do it with an original harness but by the time you get 1, you gotta make it work.. With a conversion kit, you would need an ECU, but you could buy 1 of those new also. Just has to have the right tune programmed
Old 08-01-2012, 02:19 PM
bigdog7373's Avatar
Of course it's fast
Here read the article. 1972 Chevy Nova LSX Engine Swap - Chevy High Performance Magazine
Gives you an idea of what's involved. They used a kit from a company called "turn key" which included just ahout everything needed. Its a good read so check it out
Old 08-16-2012, 11:38 AM
I have a 67 c10 shortbed with a LQ9 6.0L truck engine and 4l65E trans. I used a speartech harness and stock pcm reprogrammed by speartech. I have a friend whos now done 5 Ls coversions using speartech with absolutely no problems. they are competive with the other companys that do them. Miy harness is drive by wire.
You can give me a call 217-202-8038 Fred I will be glad to give you more info. I used the stock truck wiring which was in good shape and intergrated the fuse block that came with the harness, His instruction are straight forward and simple. Everythingis color coded and you get a life time reprogramming of the PCM in case you want to change shift points, tire sizes ect. John is always available for any questins you may have and he is the one who answers the phone. My friend has many thousand miles on his and I have 2,000 trouble free miles on my truck(finished and started up in May this year)
Old 10-12-2012, 04:53 PM
EagleMark's Avatar
GearHead-EFI.com
You can use the harness that came on the truck and save big bucks. Don't need the fuse block but some are underhood and very handy. Most of these harness are installed on engine and trans before they are installed so they come out easy, just a few extra wires need to be cut or relocated. Yes you do need the OBDII connector or you'll never be able to read codes or re-flash the PCM.
Old 10-12-2012, 04:57 PM
bigdog7373's Avatar
Of course it's fast
Old thread, the guy never responded which usually means he never did it.
Recent Modern Electronic Engines posts with photos
69 C10 IL6 to V8 Swap oldschool hero General Rodding Tech 3 06-18-2011 07:47 PM
700r transmission swap in 71 c10 HOT ROD TWAN Transmission - Rearend 1 02-07-2011 05:17 PM
projects: s10 swap and 66 c10 sbcs10 Introduce Yourself 3 03-15-2008 08:33 PM
65 c10 tranny swap 67ssguy Transmission - Rearend 1 06-20-2006 06:44 AM
1970 c10 i6 to v8 swap, how hard? chr15 Engine 2 08-06-2005 07:27 AM
