LS or not LS - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 07:54 PM
LS or not LS
ON one of the weekend moter head cable showes they said the vortec 5.7s were a LS just with a cast block. I wanted to know if my 1999 tahoe with a 5.7 vortec was an LS with a throttle body ?
Old 01-22-2012, 08:35 PM
gonzo08383's Avatar
Last journal entry: brakes
its a 5.3L vortec 5300 325ci bore/stroke:3.780 x 3.622,
285-320 hp and 325-340 lb-ft,
based on the ls platform. basically an ls with iron parts. good news is its pretty cheap to hop up. should be able to squeeze 400hp@flywheel with no problem. drop in a cam and do some head work shouldnt cost more than a grand or two at the most. check out chevy high performance's article "ls engines decoded" i have the issue, very informative indeed
Old 01-22-2012, 08:47 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
1999 is actually the last year of the "old body style" Tahoe. The 5.7 in that truck is the Gen II 350. It is not an "LS" engine. The Tahoe got the 5.3L Vortec engine in 2000. There was never an "LS style" Vortec 5.7.
Old 01-23-2012, 06:01 AM
Last journal entry: update
Correct. However, note that the '97 'vette was the debut of the 5.7L LS1.
Old 01-23-2012, 12:44 PM
Blazin72's Avatar
Wiki Edits: 19
Yes the Corvette got the new engines in '97, Camaro and Firebird in '98, Silverado and Sierra in '99 and SUVs started in '00. However, the LS1 was not a Vortec/truck engine. Hence the reason I said "There was never an 'LS style' Vortec 5.7."
