Looks good to me . I'd reuse them. I have re-ringed a couple of engines on the cheap, and reused the rod and main bearings with no adverse effects. Plastigage is cheap.
Just wondering what causes the wear in that specific location. I've seen a few bearings worn down to the copper, but none that were done this "neatly". I can't catch a nail on any of the surfaces.
This motor had 180k on it and looks really good considering. Not bad for $200. I may toss in a new set as they are very cheap, and I'm not going to be gentle on it. I was just thinking what ever caused these to wear this way may just wear down a new set as well. Thanks All! ![]()
Bogie |
Not as healthy as I thought... The rod bearings on these two looked great. Not sure what took the pistons out. Bought this as a mock-up engine a while back for $200 dollars. Seller said it was running fine when pulled.
![]() Ah well... Suppose I'll be looking for some cheap piston/rod assys.
You can still do this engine right and relatively cheap. A new set of pistons and rings and a gasket set. If the bores are good, just cut the ridge and do a nice hone job. If it needs a re-bore, many shops do a V-8 for around $100.00. If the rod bearings look as good as the main bearings, they can be reused also. Make sure you put everything back in the same positions that they came out of. What do the heads look like. Locally, I can get set of heads and valves ground for about $100.oo also. So for around $500.oo or less you can overhaul this engine to run strong for many years.
This is a very typical sudden failure of a cast hyper-eutectic piston. They go a long way past the edge but when they bust it's quick and nasty. Another thing I don't like about these is the damn circular dish. This configuration surrenders a lot of squish/quench which is in a word "mechanical octane"; OK two words. If I was rebuilding this I'd use a forged high-silicon 4032/MS75/VMS75 material replacement piston with a D Dish to bring the compression in while retaining very good squish/quench by keeping a flat surface close to the combustion chamber step and the dish under the valve pocket. You have to be careful about terminology here hyper-eutectic like FM244 and other similar alloys are used for a cast piston. High-silicon forgings like 4032 and the VMS family are not over the eutectic for dissolving silicon into aluminum, but they offer similar high wear resistance and good thermal stability that allows running closer clearances than you can get away with compared to the low silicon 2618 material which is ultimately a bit stronger but brings a lot of problems when used on street engines as the stuff really requires the engine be brought up to operating temp before using it to simply drive around. When the engine is cold the 2618 gives a lot of blow-by with resulting upper cylinder lube wash out and considerable skirt slap as the piston hunts through its generous thrust clearance. Bogie |
Thanks for the tip. This is more or less a test/mockup motor. I have a nice LS1 sitting in the corner waiting.
$20 got me 2 new assys to my door. The ring gap on the trashed pistons was right in spec. .019 and .022. I cleaned and regapped all the rings to .025 and .028 (ish) . All torq'd to angle and ready to rock. Decided on the 6.0, 317 casting heads. Compression should be about 8.6:1. Also dropped in a OEM Zr1 cam shaft for $98. 211/230 .558/.552 122.5 CL We'll see what this test mule can do next spring. ![]() ![]()
| Jaguar XJ6 Series III with 96 impala LT1... exhaust help? | tylerwerrin | Engine | 1 | 06-28-2010 08:16 PM |
| LSx engine into series III Jaguar XJ6 | dhen | Engine | 0 | 04-28-2010 02:15 PM |
| bearings - aluminum vs tri-metal | sel2real | Engine | 3 | 12-16-2005 04:10 PM |
| Rebuilding a drowned 3800 Series III | Malibucdl | Engine | 5 | 10-03-2005 12:34 AM |
| Odd cylinder bore wear | Gearhead forever | Engine | 2 | 06-16-2005 09:21 PM |
