LS Serpentine Belt Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2012, 05:18 PM
iceman36's Avatar
I need to use an after-market Serpentine belt system for clearances.
2008 Pontiac G8 L76 engine in itself is perfect for what I need,
but it has VVT (Variable Valve Timing) which I would like to keep.
I have found only one Kit that will work with the VVT, adding $250.00 to price for spacers.
I know if the kit Manufacture doesn’t make the mod they will say it won’t work!
I have been told that without the VVT on the engine the kits will work.
Does anyone know if a less expensive kit can be modified to work with a VVT engine?
serpentine belt & water pump belt coldfreshwater Engine 3 12-19-2012 07:03 AM
v-belt to serpentine Titanium Engine 12 11-07-2010 07:28 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 07:56 PM
V-belt to serpentine '86 z28 Engine 12 05-31-2007 04:59 PM
83 mustang serpentine belt strracer7 Engine 2 10-13-2003 11:24 PM
