Ls1 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-04-2008, 11:50 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Originally Posted by eatonde
Thanks for the info exchange, but its not the different styles I'm interested in but rather the different types of ignition systems you can run on the LS1.
I don't even see a place where a dizzy would go, If you enen can infact run one. Where would it be located and what manifold would have the nessecary holes/whatever???
Here is the front cover
http://www.superchevyperformance.com...p/88958679.htm
I believe it uses a small block Ford distributor, there are no holes in the intake, the dist. mounts to the new cover.
You should give google a try, it can be your friend.
  #17 (permalink)
Old 11-04-2008, 12:20 PM
RetroWill's Avatar
yes.........it uses the small block Ford dist. and also the front cover allows for a mechanical fuel pump. So...........if you get all the right pieces you can put this in anything without worrying about a computer.
c5 corvette vs. ls1 rear brake calipers FIREBIRDTONY Suspension - Brakes - Steering 1 04-06-2008 04:22 PM
LS1 in Camaro v LS1 in GTO? Longboard Engine 38 07-20-2006 11:47 PM
LS1 Radiator in 56 Chevy snimmo Engine 8 10-22-2005 06:44 PM
Ls1 and Lt1...diffrences? Rubberman2003 Engine 3 06-01-2003 04:43 PM
Need LT1, or LS1 Sycotic Engine 0 09-17-2002 08:36 PM
