Ls1 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2008, 04:47 PM
Ls1
This guy I went to see today also had 2 LS1's that He was trying to sell as core's, He wanted 200 each for them too.....
I thought about gettin them just to have 1 But I can't remember if there is any way to run them with a carb???
Do they make an intake to put a 4 barrel on LS1 heads?? Is this an expensive conversion?? Is it even worth while??
What other benefits do they have other than the reverse cooling system over a GEN I or II
Old 10-31-2008, 04:58 PM
Edelbrock makes a carb intake for them I believe!
Old 10-31-2008, 05:23 PM
RippinRon's Avatar
6 bolt mains, Cathedral style intake ports for great flow and velocity.
Old 10-31-2008, 07:07 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Advantages?
My LT1 (functionally the same as a Vortec) looks like this: 10.25:1 compression, 260 hp, 20 mpg with 3.08 rear.
My dad's LS7 looks like this: 11:1 compression, 505 hp, 27 mpg with 3.42 rear.
I would say there are significant advantages, not the least of which is weight.
Old 11-01-2008, 11:42 AM
SinistrV6's Avatar
valve monkey
GM offers carb intakes for LS1s too, GM PART # 88958675 . I'd keep it EFI but that's just my preference.
I'd spend some time over at LS1Tech.com to read up on these amazing motors.
Old 11-03-2008, 05:46 AM
stock
What were the LS1 specs stock?? cam grind/pistons/ chamber size/ runners/ CR/ HP/ FTLB TQ ect.....
I see the eddy intake comes with the timing control box, I've never messed with more than an HEI, Are these hard to figure out, Can I run it w/out a computer??
Old 11-03-2008, 06:10 AM
RippinRon's Avatar
Download the GM performance catalog and look at all the LS series crate engines, it should tell you everything you need.
Old 11-03-2008, 06:25 AM
sad
Thats the sad part, I can't find a place where GM will give ALL thier secrects away, they might give the HP and TQ but no specs for the cam or nuthin
Old 11-03-2008, 10:57 AM
curtis73's Avatar
Wiki Edits: 16
google search - first result when you type in "ls1 stock cam specs"
Everything you need to know about LS1s
http://www.smokemup.com/tech/ls1.php
Old 11-03-2008, 12:31 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
There are parts available to run a LS series engine with a carb and a distributor, no computer needed. I would imagine the new front cover and associated parts are $$$
Old 11-03-2008, 01:48 PM
parts
Hey buick do you have any Idea where I could find these parts?? I wanna run a dizzy on one
Old 11-03-2008, 02:49 PM
RetroWill's Avatar
They are in the GM Perrformance Parts catalog, or they are available from your GM Performance parts dealer.
My next project engine. LS2 with L92 heads, GM Perf intake with a FAST 90mm throttle body. I plan on a 4" stroke for 408 cubic inches. I think it will probably make close to 450 hp at the rear tires. It will be replacing a basically stock LS1 in my 1935 Sedan.
Name:	DSC04864 (Small).JPG
ID:	33892   Click image for larger version
Name:	DSC04854 (Small).JPG
Old 11-03-2008, 08:46 PM
SinistrV6's Avatar
valve monkey
Breakdown of LS1s by year
Here's a fairly complete lineup of motors and changes year-to-year...
http://www.hpsalvage.com/
Old 11-04-2008, 05:28 AM
diff GEN's
Thanks for the info exchange, but its not the different styles I'm interested in but rather the different types of ignition systems you can run on the LS1.
I don't even see a place where a dizzy would go, If you enen can infact run one. Where would it be located and what manifold would have the nessecary holes/whatever???
Old 11-04-2008, 05:47 AM
RippinRon's Avatar
There is no distributor. The LS engines use a crank trigger for timing. Download the GM catalog like I mentioned earlier and read it. Gm makes an ignition controller to run a carb its part number 19171130. It's
"Distributorless plug-in ignition system for carbureted LS engines with 58X reluctor wheel. Supplied software allows you to create custom vacuum advance curves, timing curves, program lo and hi rpm rev limiter and more! Compatible with LS1/LS6 and LS2/LS7 ignition coils.
And the carbed intake is 88958675.
c5 corvette vs. ls1 rear brake calipers FIREBIRDTONY Suspension - Brakes - Steering 1 04-06-2008 04:22 PM
LS1 in Camaro v LS1 in GTO? Longboard Engine 38 07-20-2006 11:47 PM
LS1 Radiator in 56 Chevy snimmo Engine 8 10-22-2005 06:44 PM
Ls1 and Lt1...diffrences? Rubberman2003 Engine 3 06-01-2003 04:43 PM
Need LT1, or LS1 Sycotic Engine 0 09-17-2002 08:36 PM
