LS1 Adapter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 12:04 PM
IATECH's Avatar
Gary
Last journal entry: 1950 Mercury Project
LS1 Adapter
Attached is a DXF file for a LS series engine to older SB chevy engine mount. Can be cut out of 3/8" steel or 1/2" aluminum to allow for countersunk hardware. Cut 2 out and countersink opposite sides.
Old 04-21-2012, 04:50 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What will open a .dxf file????
Semper Fi
Old 04-21-2012, 05:23 PM
Two8tyThree's Avatar
Last journal entry: Picture of delivery
.dxf is an AutoCad file
Old 04-21-2012, 05:49 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Swapped it to PDF but no dimensions.
Old 04-23-2012, 08:53 AM
IATECH's Avatar
Gary
DXF files are CAD files that can be imported to CNC & CAM software to be cut out on various computer controlled machines. I will attach a version that will include the dimensions so that you can build one without the high tech machines.
LS1 vs. LS1(364) Chevy 84 Engine 8 07-04-2008 02:10 PM
T-5 adapter ???????? leadfoot8123 Transmission - Rearend 1 07-20-2007 10:29 PM
LS1 in Camaro v LS1 in GTO? Longboard Engine 38 07-20-2006 11:47 PM
Wheel Adapter? Fragzem General Rodding Tech 6 06-26-2005 10:10 AM
???is there an adapter??? young350 Engine 3 06-28-2003 08:54 PM
