Is this the one? http://www.jegs.com/i/Edelbrock/350/...39#moreDetails That should be pretty simple to install and it eliminates all the computer crap that the efi requires.
Wow, expensive carb. Not to pick on you or anything but it's NO2 not NOS. NO2 is nitrous, NOS is a company name and what ricers say. It you drive a chevellle then you're not a ricer.
If you're on a budget you may want to use a less expensive carb because the price of a cam for an ls engine if going to be substantially higher than that of a regular sbc. btw do you have any pics of the car? 1970 chevelle is my favorite car, i just haven't found one in my price range and no one wants to trade for a 78 firebird. |
I bought the MSD 6AL box and GMPP singale plane intake for a 5.3 that I putting into a 51 Chevy pickup. I havent done anything with it yet cause I still need to get engine mounts and figure out how I am going to run the power steering and alternater. You have to use a later style alternater for a serpintine belt but unfortunatly the holes don't line up with the stock bracket.
I have talked to Comp about a cam and they can recommend something but after you buy the roller cam, springs, hardware, and timing chain its about $1000. Heres a link to Wegner Automotive Research. They have done alot of testing for GM with the carb intakes and also have a adapter that bolts onto the front of the engine and uses a Ford distributer in place of the MSD set up. http://s41657.storefront-solutions.com/default.aspx |
I've used Jones Cam Designs (jonescam.com) and since you have gone this far, you might as well get something special for the old girl. Mike hits it right first time, everytime. |
The stock efi cams have a wide lobe center angle not really suited for carb applications. I was thinking of using a stock 99 LS1 cam in my 5.3. After looking at Texas Speed they can do any LSA.
I googles gen 3 carb cams and found a link to a magazine article where they tested a carb and efi motor using the same heads and cam. The results were simular but could have been better. |
| 283 custom cam and 4/7 swap | Dirty Biker | Engine | 41 | 12-10-2010 11:13 AM |
| Cam swap Questions | wayfast77 | Engine | 3 | 10-18-2006 04:52 AM |
| Mileage cam swap. | 71C10 | Engine | 5 | 06-23-2006 12:28 PM |
| 87 octane engine cam swap? | 71C10 | Engine | 6 | 01-20-2006 10:50 PM |
| Should I swap myXE268 for a summit k1107 cam? | 4speed57 | Engine | 13 | 07-15-2005 09:32 PM |
