LS1 engine accessories: Any other power steering pumps work with the Camaro setup? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2009, 08:30 PM
In attempting to install the F-body pump on the LS1, my suspension cradle is slightly too narrow. I looked at my 1998 Sonoma with 2.2L, and the pump is similar, with a 5 1/2" pulley rather than 6 1/2".
Has anyone:
1. Used a different GM pump and pulley assembly successfully for a clearance issue? Will the Sonoma pump or another vehicle work?
2. Know which pulleys from other GM vehicles interchange on the F-body pump?
I see that the 04+ GTO pump may work, but do not like it's translucent reservoir. It just looks bad. Visual is 90% of hot rodding.
Perhaps I could use it and setup a remote reservoir under the fender?
Old 07-21-2009, 05:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your PS pump is a Type II, w/either a .750" or .660" shaft. (The Type I has an integral steel tank.)
There is a 5" pulley. It is for a .750" shaft. Part number is 10166335, goes for about $40.00 new.
Summit sells a nice aluminum reservoirs, p/n 340202, but it's steep @ $81.00. Nice hose, fittings and the 16 mm to AN -6 (Summit p/n 991955, $6.25), etc. is another $50.00, give or take.
The above info is in part from the May Car Craft.
The idea of a hidden tank is a good one, IMO- I'd opt for that, personally. BTW, a truck and F-body alternators appear to interchange.
power steering unit on a chevy 5.7 engine tommy evans Suspension - Brakes - Steering 2 05-26-2009 03:50 PM
Power Steering Pump Avalability?? HotRodMan Engine 2 02-05-2009 10:02 AM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
