LS1 headers for narrowed Camaro subframe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 03:51 PM
Does anyone know if someone manufactures a set of headers for an LS1 that is sitting in a 1979 Camaro subframe. The catch is the subframe has been narrowed 3". I have tried GTO manifolds, corvette manifolds and a set of block huggers (which put the exhaust smack dab in the middle of the crossmember and too close to the motor mounts). I didnt think I would have much luck finding a set but maybe someone has done this before. The plan at this point is to TIG together a set from some 1 5/8 mandrel bent tubes and some nice 2.5" 4-1 collectors.
Anyone run an X or H pipe with their LS1?
Old 09-25-2008, 04:11 PM
RetroWill's Avatar
I have a dual setup 2.5" with the left side crossing over under the torque converter and then paralelling down the right side...through an "X" pipe to a Spintech 2-in, 2-out muffler. It sounds pretty nice, seems to flow well.
Old 10-20-2008, 08:35 AM
SinistrV6's Avatar
valve monkey
Try the 5.3 manifolds from a Chevy/GMC truck. They exit to the rear. The F-body guys swap 'em side-to-side to mount turbos.
My new Street Rodder mag has an ad from Edelbrock for new LS1 tight fit headers, too.
HTH
Old 10-20-2008, 12:59 PM
Ill look into the 5.3 manifolds.. Thanks for the hint.
Old 10-20-2008, 02:18 PM
SinistrV6's Avatar
valve monkey
These pics might help..
Trailblazer/Envoy manifolds in first pic
F-body, C5vette, Truck and GTO in second pic
ID:	33403   Click image for larger version
Old 10-20-2008, 02:38 PM
Is that a truck manifold in the 2nd pic on the top left side. I assume its paired up with the one on the top right?
Old 10-20-2008, 03:51 PM
SinistrV6's Avatar
valve monkey
F-body -Camaro/Firebird (top L&R)
C5 Corvette (2nd from top L&R)
Truck (3rd from top L&R)
GTO (Bottom L&R)
72 camaro subframe in my 72 nova 396nova Suspension - Brakes - Steering 4 07-09-2011 05:58 AM
Mustang 2 or Camaro subframe 38chevysedan Suspension - Brakes - Steering 1 08-13-2007 10:22 PM
LS1 Camaro 1/4 mile times NAIRB Engine 3 04-18-2003 06:19 AM
Headers best ceramic costed for '73 SBC Camaro Rascal Engine 0 09-08-2002 06:40 PM
help!! how to put headers on 83 camaro candi743 Engine 6 03-02-2002 09:23 AM
