LS1/LS2 swap into an s-10???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 05:50 PM
kuhn-77's Avatar
Build it right the first time
A friend of mine wants to put either an LS1 or an LS2 into an s-10 chevy, has anyone here done this swap before?????
I have put a carburated 350 small block into an s-10 before, with a TH350 transmission without problems before but i dont know anything about the Fuel Injected LS-series motors or how to do the wiring involved for them?????
help plzzzzzzz
Thank you
Old 04-01-2007, 09:27 PM
Go here
http://www.ls1tech.com/forums/
Old 04-03-2007, 08:46 AM
There are specialized companies for wiring. I put a LT1 in my s-10 and had lt1350.com do my wiring. They took both harnesses and spliced them for a plug and play on my end, and reprogramed my pcm. As far as clearance, you might need to offset the motor to the passenger side a little to clear your steering shaft (and/or move your shaft). I also needed to notch the frame and box it in with 4X4 angle iron on the passenger side for the exhaust (weld some 3/8 plate steel on the outside of frame for extra strength). But done right it will be just as strong as factory.
Good luck,
Damian
Old 04-03-2007, 09:09 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Friend of mine just put an LS-1 in a 2000 something Blazer Xtreme 2WD. Cool as Hell but man what a job! He bought a wiring harness and headers off some guy on the internet that were supposed to be plug n play. He spent all winter rewiring it correctly and had to have the headers cut apart and redone by a local shop. It is a TIGHT fit!
Old 07-31-2011, 07:27 PM
There is a company in Florida called Current Performance Wiring. The owners name is Jarrod, 1-727-844-7570. He does wiring harnises for S-10's and use to do complete makover on S-10. He has alot of products and alot of information. He builds a long tube header for S-10. 1 5/8 tubes and 3 in collectors, they are great. Give him a call, he will talk to you. He has a business to run so do not tie him up all day.
A friend of mine used Jarrod to help him put a LT-1 in and S-10.
Good Luck,
Junkyard
Cam swap Questions wayfast77 Engine 3 10-18-2006 04:52 AM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
Swap meet score Bluepen Hotrodders' Lounge 5 10-07-2004 08:49 AM
Engine Vacuum is showing 10 and no higher? ataririder Engine 42 02-18-2003 07:12 PM
40 ply/s 10 clip gcorbit Suspension - Brakes - Steering 0 01-28-2002 03:53 PM
