ls1 valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2009, 12:04 AM
sscanrun's Avatar
ls1 valve springs
i just found out that i can put some ls1 beehive valve springs from comp cams on a set of vortec heads
But.....
1.What is the stock ls1 valve spring lift ?
2.Can i put some stock ls1 valve springs on
SOMEONE PLEASE HELP
Old 05-02-2009, 12:16 AM
DaSouthWon's Avatar
I put up the tools against$300
The Vortecs aren't good for more than .500 without machining.
Old 05-02-2009, 05:25 AM
Sinister's Avatar
More like .450 from what I've read.
Old 05-02-2009, 05:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
But.....
SOMEONE PLEASE HELP
1. The installed height is 1.8", IIRC.
2. Yes, but they are too weak for anything except a stock cam. Something like 80# on the seat.
The cheap method is to run a "Z28" or "Z28 +.100" high lift valve spring with the inner damper removed. "Ghetto grind" the retainer to gain retainer to seal clearance.
Comp Cams #26915 and #26918 beehive springs are direct replacements for the Vortec spring- no machining. #26918 springs offer more lift capability and pressure. Use Comp Cams steel Retainer, #787. +0.050" locks can be used to gain some extra clearance; make up the spring installed height by using shims under the spring.
Old 05-02-2009, 10:25 AM
sscanrun's Avatar
The Cam Am Going With Has A 477 Lift
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Valve Springs Lift juiced66malibu Engine 2 03-08-2008 11:54 AM
valve springs, valves, push rods, and rocker arms elcaminodragster Engine 7 01-28-2008 08:48 AM
Valve springs @seals JMEDLEY001 Engine 1 12-12-2006 09:25 PM
Can I exceed the lift that is recommended for my valve springs? surfshark Engine 7 11-18-2006 12:13 PM
