ls1 vs 5.3 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2013, 08:32 AM
ls1 vs 5.3 question
How do they compare I know the ls1 is alum block and the 5.3 is a truck motor but how do they compare in hp I'm thinking about putting in a late 70s early 80s trans am thanks
Old 06-29-2013, 10:03 AM
vinniekq2's Avatar
check the head flow and cam timing on both engines,if you plan to leave the engine stock.the size is slight difference but we all want as much as we can get
Old 06-30-2013, 02:29 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Thought I read the LS bottom end flex under high performance use at a certain hp level and the aftermarket cast in a fix for that.
ls1 gto question doubleD_white_t'a Hotrodding Basics 19 01-20-2009 09:56 PM
LS1 harness question flynbrian48 Electrical 1 11-20-2007 01:25 PM
LS1/LS6 question 70bird Engine 1 11-06-2005 01:36 AM
A Question about LS1 Engines TNTster Engine 5 03-28-2005 12:53 PM
LS1 swap Question HOTWHEELSBOY28 Engine 1 02-15-2004 06:33 AM
