LS2 in a 37 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2008, 06:46 AM
Last journal entry: 1937 Ford Club Coupe LS2 build thread
LS2 in a 37 Ford
37 Ford (Steel) with a TCI Mustang type front end......Bought a GTO LS2 Engine/Trans set-up (Auto)......anyone been down that road.....looking for Issue's that will be cropping up......Oil Pan, Radiator, Headers etc...Pass along your info with what parts/ supplier was able to make the problems Go Away...........
Thanks in Advance
Ken
Old 07-08-2008, 07:11 AM
I have never done this swap but as a I understand it ... the GTO LS2 has a different oil pan than the Camaro type.
Old 07-09-2008, 02:02 PM
streetrodderbn's Avatar
Certifiable Streetrodder
There actually is a lot of room in the 37 engine bay if you replace the firewall with a *****in or Direct sheetmetal unit. I just put together a 37 club coupe for a customer with a 502 bbc. I would contact street and performance for a catalog, they have most of the conversion parts worked out, and you can learn a lot just from the catalog pictures!
Old 07-09-2008, 06:53 PM
Stu Cool's Avatar
Make it cool, low and drivable
Last journal entry: Installing New spindles and brakes
Surf on over to www.ls1tech.com and introduce yourself on the Conversions and Hybrids Forum. Lots of folks there that have swapped these engines into everything imaginable.
Pat
'98-'08 Ford Ranger Frame w/ '37 Ford Body? jbundick Hotrodders' Lounge 8 12-28-2007 05:31 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
37 Ford trunk hinges APalusky Body - Exterior 3 12-17-2006 09:26 PM
9" ford rearend 37 ford melbishop Transmission - Rearend 3 12-09-2001 09:15 AM
40 Ford Dash in a 37 Ford?? Carnut39 Interior 1 12-05-2001 05:51 PM
