ls6 crate motor upgrades?
Hello newbie onboard, I'll make this short I have a ls6 454 in my 55 chevy xe 284 hydraulic cam , single plane intake, 750 dominator carb, 373 gears out back , 325/50 drag radials, 400 turbo 4k stall convertor. (cam is about 240-246 duration, 575-580 lift). My best times are 11.99 at 112 the car is 3850lbs with driver, what do you guys think should I buy some oval port heads like all the mags say now or a big roller cam, if heads then who's do you like or well done 049's?. Thanks
Thanks for the reply super streeter, I have had the heads flowed but I dont have the numbers (rookie mistake) , the intake is a weiand team g single plane which is not ported the heads, if that is worth anything I'm not sure. The compression in the cylinders has been checked and it ranges from a low of 185 to 200 psi , so I think I'm close to not being able to run pump gas, although in the great white north we get 94 octane ,at a buck a litre. 11.5 to one comp probably will take me out of pump gas which I would like to stay with. I'm wondering about the difference in a solid cam as opposed to a solid-roller cam, big diff in price, what about performance? In the tens would be awesome, keeping my heads would really save me some cash too. The chassis is pretty good with a 12 bolt 3.73's ladder/bar coil over, mini tubbed 28/12.5 bfg drag radials, the front has 6 cyl springs and 90/10 shocks, weld pro stars all around, the 400 turbo is reverse manual valve body, with a neil chance 10" convertor, (4000-4500), cage with full interior, the headers are 1.75 *3.00 hedmans leading to 3inch flowmasters tailpipes are 3.5inch s/s out to back bumper, (I'll get some pic's attached if your interested) Also roller rockers and a stud girdle on the valvetrain.
I'm with ya big bad chevelle , but I would like to sort this combo out to its max, before I juice it. If I could run low /mid 11's with the 3.73's and a 28" tall tire I would have some rpm's left for 150hp of nitrous, for sure in the tens then and still drive on the highway at about 2800-3000 rpm. Just love to hear from someone with ls6-ls7 heads and a heavy car, find out the potential of the combo.
bump
