LS7 build questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2011, 10:52 AM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
A little about the motor - Going into a weekend warrior. Red-line is going to be 7000 RPM. Trans is going to be a T56.
Already have the block, rotating assy, and heads. The rest is still in the works.
LS7 New block
4.125 Bore
4 inch stroke
11.9:1 Compression JE forged pistons
Eagle 4340 crank and H beam rods
Heads
World Warhawk 12*
2.200 int. / 1.600 exh. S.S. valves.
Intake Runners - 285cc
Exhaust Port - 106cc
1.8:1 Roller rockers
72cc chambers
Int. Exh.
.1 55 33
.2 117 63
.3 184 105
.4 243 141
.5 289 166
.6 316 183
.7 336 193
.8 318 200
Intake / throttle body
Fast Intake manifold (ported) w/ 102mm throttle body.
Cam / lifters
Comp Cams XFI286R113 w/ solid roller lifters
RPM Range 2400-7000
Duration Int 286 exh 293
@ .050 Int 251 Exh 256
lift .698 int. .693 exh. w/ 1.8 rockers.
What type of performance should I expect out of this engine? Goal is 600-650 horsepower on pump gas. Will be custom tuned once its together and running.
Old 08-08-2011, 02:33 PM
cool rockin daddy's Avatar
Don't understand the question. You bought all the parts, did you not have a goal in mind when you did? Dyno test after it's assembled is the only true indicator of how much power it will make.
Old 08-08-2011, 11:49 PM
crowerjunky's Avatar
JOHNNY
should easly make 600hp---if you hadnt already got the cam i know a guy that can give ya a bad a** cam for that motor an can tune it for ya dont know what he may charge but he is good at what he does ill put my rep on it ill give his number if you want it just messageing me an ill give it to ya
Old 08-09-2011, 04:11 AM
Eric63M's Avatar
cool rockin daddy - Just seeing if anyone thinks there may be a problem with the setup like getting it to run on pump gas, don't think it'll meet the goals, diff cam.
I've been planning this build for about a year now, Finally committed since I've been back in Iraq. Bought the block earlier, just order the rotating assy and heads. Just making sure the other parts are going to be in line for the goal, not too small of a cam or throttle body's to big causing issues....ect.
Dyno testing is already planned out, going to use the same shop that tuned my LS1 currently in the car (mild compared to this)
F-BIRD'88 - Thanks for the heads up. I think it should be fine on pump gas (have a sunco station down the street from my house if needed), been running the current LS1 w/ 11.5:1 on 93 without problems, not sure if the extra compression will require a higher grade, It'll be put to the test during tuning though.
crowerjunky - shoot me a message with the guys e-mail address. Never hurts to get a second opinion on the cam. Thanks for saying it should easily hit the goal, shop that did the tuning on my LS1 said this motor should easily hit 600hp, and with proper tuning could probably put 600-625 to the tires.
Old 08-09-2011, 08:36 AM
S10xGN's Avatar
Gotta love a turbo!
Check with Comp Cams on using those rockers. The 1.8 ratio rockers were primarily made to give stock cams a slight boost, but are not designed to work with the aggressive lobe profiles of aftermarket cams. Also, might want to hang out some in the LS1Tech forums...
Russ
302 SBC Build questions dreamcar Engine 23 06-11-2011 02:33 PM
454 289/781 build questions tls3028 Engine 2 03-07-2010 08:35 PM
383 Build questions ekacpuc Engine 7 12-18-2009 08:21 AM
SBC Build, Some Questions RandyJ75 Engine 8 06-11-2009 07:08 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
