LSA idle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 07:15 PM
cowbay's Avatar
LSA idle question
I am building a 383 stroker. It is going to be a somewhat aggresive motor. The cam I am going with will probably be a 236 int 242 ext. My questions is LSA 110 or 112. I am leaning on on the 112 for a better idle quality. What is everyone feeling on LSA
Old 05-18-2008, 07:41 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
It depends on your application. Auto or manual? heavy car or light? Gears? street or strip? You gotta post everything you know or its really hard for us to help.
Old 05-18-2008, 08:02 PM
cowbay's Avatar
Basically I am building a 63 chevy that is to appear visually as stock on the outside but to have some substantial power. This car shall be primarily street driven but will see the track 6-8 times a year. Cam is to be a solid roller.
Motor will have 2.02 1.60 fuelie heads ported and polished flows 250 cfm, intake is origional from a 63 327 that has been ported. Carter carb that has ben modified to flow around 750 cfm. Overall compression should be around 10.5 to 1
The car wieghs 4,000 LB with driver, M20 4 speed, 4.11 gears, tires on it will be 28" tall.
Old 05-18-2008, 10:19 PM
curtis73's Avatar
Wiki Edits: 16
I think either one will work fine with that setup. The 112 will still have quite a lope to the idle and make a bit flatter torque curve, but might give up substantial peak power.
I'll run some dyno simulations tomorrow and maye post some screen caps of both scenarios.
Old 05-19-2008, 07:07 AM
cowbay's Avatar
You the man! Thanks!!!
Old 05-19-2008, 11:16 AM
Cams are always about tradeoffs. Give up something to get something else somewhere else. Wider lobe centers help the idle and broaden the torque curve, but give less top end horsepower.
BTW, you can keep all that stock-appearing stuff, which costs much horsepower, but with that cam, it ain't foolin' nobody who knows engines.
Modest proposal: Put on the best modern aluminum heads and intake, grind off the logos, stock rocker covers and paint it all orange, use the stock air cleaner and a small cap HEI with black plug wires. You'll be foolin' the same number of idjits that it is a stocker and won't fool the same engine guys who can hear the cam, but you'll have 75-100 more horsepower on the top end.
thnx, jack vines
Old 05-19-2008, 12:37 PM
cowbay's Avatar
Basically I am building this car to motor to enter into the stock appearing drag category which has become somewhat big around here. Not looking to hide anything when I start the car up
Old 05-19-2008, 12:53 PM
I think the 110 lsa will have slightly better throttle response. And the 112 will have slightly better idle. Most likely not noticeable either way. 2 degrees isn't that much of a difference. If you were considering 114 LSA then there would be more of a difference to think about.
But a 4.11 gear used with a 4 speed trans would work better with a narrow power band (in theory). So, I say go with the 110 for best et or a 112 for best idle.
Old 05-19-2008, 02:09 PM
You're building the car to race it. Don't select the cam based on idle quality.
Pat
Carb tuning issues - 750 speed demon lightningcow Engine 48 07-01-2009 08:32 AM
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 07:03 PM
Help tuning 383 for street use strokey Engine 29 04-11-2008 06:51 PM
Holley idle circuit tuning question curtis73 Engine 25 08-03-2007 01:11 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
