LSD 14 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 03:16 PM
busted knuckles
LSD 14 bolt
I wanna hear your recomendations on some kind of limited slip/posi for my 14 bolt 10.5 rearend on my 1 ton chevy thats becoming "mucle truck"
Old 04-27-2011, 05:13 PM
prostreet6t9's Avatar
Differential/Driveline
Eaton makes a great unit. #19610-1 for 456 and lower ratio.
#19689-1 for 410 and higher ratio.
The Detroit locker unit is a good piece also #225S-10. Keep in mind to use the Detroit you will need a STOCK OPEN carrier.
Better core block for sbc 383, 4-bolt flat or 2-bolt roller? Cousin_Joe Engine 24 02-08-2008 08:50 AM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
