Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lsx swap worth it?
Old 10-10-2012, 02:50 PM
bigdog7373's Avatar
bigdog7373 bigdog7373 is offline
Of course it's fast
Originally Posted by vinniekq2 View Post
you keep posting LS-X ther is an X in the series.Go with the 5.3 for economy.the LS-3 has enough everything in one package at 430 hp,a hot cam and minor tweeks is 480 hp
like I posted above,its the roller cam/fuel injection and ignition that makes it a nicer package. spending 12 k to save $100,oo worth of fuel is not good math.If you want it all in an old car the the LS line has a lot to offer.
Old engines can accept fuel injection,roller cams and better ignition. The cathedral heads do offer more potential. O/drive transmissions come in many varieties,but at a cost
Lsx is just a way of just saying ls series without specifying which one. If i do the swap it will definitely be a 5.3 since they are so abundant.
One thing that worries me is the transmission. I've heard you can use the flywheel from a 4.8L 5 speed truck and then just bolt up the rest. Can anyone confirm this is correct? What about the clutch linkage, will it clear everything?
