Originally Posted by ap72
stock bellhousing will work fine
you'll have to make your own z-bar
you'll have to make a fuel system
any clutch with the right spline count will work
and you can either get a computer programer, or skip the stock route and run MS
Those are costs you need to factor in, but they're not as much as people think.
Would you happen to have a picture that explains how the z bar mounts normally? I'm still not clear on how it all goes together since i'm used to hydraulic clutch.
But that brings up another question. Could i convert it to a hydraulic clutch? or is that more work?
