Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lsx swap worth it?
  #48 (permalink)
Old 10-13-2012, 07:31 AM
ap72 ap72 is offline
Banned
Originally Posted by bigdog7373 View Post
The engine was rebuilt about 3,000 miles ago and has some extra's, and the trans was rebuilt about 500 miles ago. I don't think $600 is out of the question.
Also i think $1500 should be about right because i already have the transmission remember. Say $500 for the engine, ecu, and harness. Then the rest for accessories and and other pieces to make it fit.
A transmission crossmember is almost free as usually you can cut and weld a stock one. The expensive things will be a driveshaft, mounts, clutch, fluids, possible different accessory brackets, different intake manifold, tuning, headers, air ducting and filter, maybe a few random sensors need to be replaced- it adds up fast, BTDT. If you don't want to believe it'll take more DO NOT KEEP A JOURNAL. It'll just make you cry. 2G seems reasonable, assuming you do a good job and most of the work yourself.
