So that being said, what do i do about the clutch linkage? Can i modify the pieces to work or what? |
The more i read about it the more it seems like putting the muncie on the ls engine is going to be a huge Pita
1. As for the clutch linkage, scoggin dickey makes a mount that bolts on to the ls to mount the z bar, so problem solved there. Here's an article i found about it: Engine and Transmission Swap Gen III - Car Craft Magazine |
Car Craft is a magazine dedicated to selling parts, keep that in mind any time they write an article.
Here's how to bolt a muncie onto a 5.3L using only stock parts. For the TH 350 you'll need a spacer for the flex plate, it's like $40. That's it. No extra 5 bajillion dollar conversion cost. Most "hotrodders" today can't build anything unless its been approved by a magazine editor and delivered by the UPS guy- that's not building, that's buying. |
![]() I actually saw that video while i was searching! Thats what i was talking about with the 4.8 5speed truck flywheel before, but then the article said that it would cause problems. Well i guess they lied. SoSo what im seeing i need is the flywheel, the pilot bearing, the bracket for the z bar, and the correct clutch and i should be good. Only thing is that in the video he mentions not to install the pilot bearing all the way, but then in the article they mentioned a bearing made specifically for the application. So if it's no overly expensive i think it would be better to go with that one Last edited by bigdog7373; 10-10-2012 at 09:31 PM. |
check out pirate 4x4, chevy thunder drive by wire, ls1tech, lt1swap.com, nook and tranny lsx info, gmefi.com for a bunch of info on the ls series engines. good stuff for a read-thru before spending money. don't worry about the car end of things, if you have the engine and trans etc it will fit into lots of different vehicles if you decide the old iron is too heavy or for whatever reason. a guy i work with put a 5.3 truck engine in his mustang and then threw a turbo on it and it worked out fine. you will have no problems if you have a few fab skills. I would recomend an overdrive with whatever engine you use. there is a reason most newer vehicles come with 5 gears or more, less rpm spread between gears, so you're not wringing the engine out like a wet rag before shifting, plus a good overdrive for mileage. also, there is always somebody looking for ls engine swap stuff if you get into it and then change your mind.
good luck there is a guy on the ls1tech that has pics in the forums. it's a corvette engine in a '76 I think. |
Everything you can do to make a short block and valvetrain easier to roll over is going to pay dividends in fuel economy. It's a huge part of the magic used to get those amazing power/economy numbers from modern engines like the LS series.
Quick crude example... Take two mostly identical engines, except one shortblock requires 40ft/lbs to roll over using regular oldschool piston rings, the other uses a modern low-tension ring pack and requires only 13ft/lbs to roll over. That's a constant savings of almost 8hp at 1500rpm. If your car cruises at 2500, that equals a constant savings of roughly 13hp while you are driving down the hiway. As a bonus, WOT at 7000rpm, the low-tension shortblock would have about 36 more hp on tap. If you decide to go old school, do yourself a favor and build it with modern hyper pistons, skinny low tension rings, and a compatible cyl wall finish using torque plates. Not only will the engine will last a lot longer, but even more important, less friction in the cylinders will pay fuel economy dividends for the entire life of the engine. Less friction in the cylinders also means less heat being put into the cooling system. Oil temps come down as well. Proper clearances and thin synthetic oil will help too. |
| Need g-body LSX Frame no | veltboy314 | Hotrodding Basics | 5 | 11-20-2011 01:53 PM |
| My LSx/4L65e Swap on my '69 C10 SWB | Ford_Assassin | General Rodding Tech | 9 | 01-30-2009 03:48 PM |
| lsx motor? | tornado-tech | Engine | 6 | 05-25-2008 10:55 PM |
| 2.29 to 2.73 worth the swap over? | montea | Transmission - Rearend | 5 | 03-24-2005 11:41 PM |
