you going to run headers..
bye bye budget.. for s_it's and giggle, start a journal, and list the cost as you go.. to give an idea. my c-10 is a small block. I'm changine to big block headers 580.oo (coated) brackets and mounts 159. front assor dress(brackets and alt/ps pump/ac compressor/ a/c lines/ power stear lines/ belts 1200.00 (remember your ls will not have us threads it be metric and the ps hose ends are different and you'll be paying for these to be made.. same with a/c hoses, if you can connect to the exhaust under the car now.. say 40 bucks if you do the fitting/welding yourself the custom coolant hoses the electric fans the relays the fuel system.. please start a journal.. I'd love to see you come even at double your 1000.00 swap budget.. I've seen enough of these stuffed into g bodys to know what the cost really is like.. good luck tho.. wait till you get the sticker shock on the 02 senders cost.. oh, and plan on the oil pan not clearing, most go with the gto pan, and pick up |
I can get junkyard fans for next to nothing. I was planning on running shorty headers and they tend to be a lot cheaper, plus the car is getting lowered so i don't want any ground clearance problems with long tubes. I know the little things add up, but I'm pretty good add staying within the budget i set, plus i have a lot of parts that i will need already. |
| Need g-body LSX Frame no | veltboy314 | Hotrodding Basics | 5 | 11-20-2011 01:53 PM |
| My LSx/4L65e Swap on my '69 C10 SWB | Ford_Assassin | General Rodding Tech | 9 | 01-30-2009 03:48 PM |
| lsx motor? | tornado-tech | Engine | 6 | 05-25-2008 10:55 PM |
| 2.29 to 2.73 worth the swap over? | montea | Transmission - Rearend | 5 | 03-24-2005 11:41 PM |
