LT-1 distributor module????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2011, 12:05 PM
bsa_bob2's Avatar
I finally have been brought to this conclusion. the mechanic at a SEARS store told me theres a module ;expensive] inside this frontal distributor that breaks down when it gets warm then straitens out to normal once kooled off.Has anyone with an [ that knows about these modules any info at all please thank you ps i know there another post close to this but hopefully i'll ge some action on this one instead -[ 96 lt-1]
Old 08-07-2011, 06:28 AM
Steel's Avatar
The Ultimate Lurker;)
That optical sensor that he is talking about will also cause other problems than just a hard start. Generally, you will also experience high RPM missing or missing throughout the RPM range. Have you pulled your codes?
Old 08-07-2011, 08:38 AM
bsa_bob2's Avatar
Thank you steel i 'm thinking.like this It just seems to be unreliable voltage somewhere in the system. But as far as the codes i haven't done this yet. Tomorrow i'll call my mechanic and get him in the codes situation.
Back to the previous paragraph.
I can go start this kar right now and it will hit everyime, after its warmed up to operating temp. and it will hit everytime you crank it over in the garage or out in this awful high heat we'have been having she'll start. I even let it set after shutting her down.As then the engine temp rises 10 degrees or so and it still starts. I cleaned the battery posts again yesterday but i am thinking ---this week i'll brush them posts till they shine like new.See what that does.
The funny part is--if there is a funny part----is it could fix its self and i won't have a clue what was wrong.!!! You ever done this,it can be maddening for sure bob s
Old 08-07-2011, 08:58 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Once the engine shuts off, its does get a bit warmer since the hot coolant is no longer circulating. I notice this all the time on my LT1s. And with them being iron blocks, they take their sweet time coolin down. Are you running the orange Dexcool by any chance for coolant? If so, I recommend switching over to the green antifreeze. Several LT1 owners, including myself, have switched over to this and the engine seems to run a bit cooler. Plus its cheaper to replace too.
Old 08-07-2011, 09:41 AM
bsa_bob2's Avatar
No dexcool-just plane ole green anti-freeze. I didn't know this dexcool ,was what the car called for , so i just put in the green.thank you------------ anything else???? bob
Old 08-07-2011, 10:17 AM
Steel's Avatar
Intermittent problems can be a pain to diagnose that's for sure. Definitely sounds power related to me, unless you have a starter that is on it's way out. I would do as you are already doing, clean up all terminal connections and make 'em tight. If it keeps occurring move on to other things like bad cables, starter, or battery.
Old 08-07-2011, 11:13 AM
Last journal entry: It starts...
most s10 guys have gone away from dex-cool... corrodes the intake gasket. i swapped mine a lil after i bought the truck.
Distributor Module??? gizz436 Engine 11 06-29-2010 11:13 AM
My MSD HEI module fryed ss396si Engine 4 06-02-2009 02:57 PM
HEI Module horvath Engine 8 09-09-2003 06:57 AM
control module? twistedtrik Engine 8 03-13-2003 06:39 PM
EEC IV Module shadowmary Electrical 2 01-13-2003 07:14 PM
