LT-1 having problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2007, 11:35 AM
I have a 1994 caprice classic ls with the LT-1 5.7L, and the problem is the car runs like crap when it first starts. Then when it warms up the engine stats to run fine but, the elec. fan stays running intill car is shut off.
Old 11-30-2007, 12:05 PM
Sounds like the dedicated (to the computer) engine temp sensor is failing. My take on the symptoms is it's telling the computer the engine is not only warm but perhaps overheating. In the first instance, the engine doesn't receive cold start fuel enrichment so it runs crummy till it warms up to where the F/R is correct for the actual temp. The second instance is that the computer thinks the engine is always hot so it switches the fan on and holds it no matter what the real world is doing.
Bogie
Old 11-30-2007, 01:02 PM
re
Thanks, before this started the car would cut out bad so then i put a fuel pump in it hopeing that would fix it and it did'nt. Then i put a new distributor form summit raceing after i did that thats when this started to do what it is doing now.
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
I Hate Electrical Problems! tm454 Hotrodders' Lounge 20 09-28-2003 07:40 AM
corvette LT 1 arborlis Engine 2 04-24-2003 04:35 PM
