LT-1 Piston-to-wall clearence - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2003, 12:44 PM
lonewolf3197's Avatar
Chief Petty Officer, USN
Last journal entry: My Monte Carlo
Wink LT-1 Piston-to-wall clearence
Hi Everyone,
I am a new member and I am currenctly rebuilding my 94 Z-28. I have been tinkering with engines for a few years, this is my 6th or 7th rebuild and I want this one to be done the right way. I am trying to find out the correct piston to wall clearance. The engine is a standard bore and the cylinders look very good and should only need a light honing. I am using Speed Pro cast pistons ( trying to keep it under buget). I have looked in all my manuals, on line and I even called the dealership to find out the answer, still no luck.. Thanks in advance for your time.
Old 12-27-2003, 02:23 PM
lluciano77's Avatar
You need to check with Speed Pro for the correct clearance. The pistons expansion is important, not the cylinder wall. Cast pistons, forged pistons, and hypereutectics all expand different amounts.
Old 12-27-2003, 07:19 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Wall clearance is determined by piston type as touched on above. When you do a rebuild, the piston manufacturor will account for the proper clearance given that the machinist gets the bore correct. It is very important that the cylinders are a true .030 over bore, for example, instead of .031 or .029.
Chris
