Lt Blue Poly
GETTING TIGER STRIPS??? ANY HELP!!!!
Lt Blue Poly
What Is The Best Temp For Spraying This Paint?
Dentdave ??
YES IT'S A NEW GUN STARTINGLINE BY DeVILBISS HAS 1.3 AND 1.8 NEEDLE AT THE GUN IS 45 psi
if its not spraying heavy on the top and bottom and light in the middle are you making an X pattern after the second coat? lower grade bases will do it more than the good ones.
lt blue poly
thank's will try that!!!!
could be, looking at the pattern while holding back the trigger should tell the story. Still, I use the X and fog even with the good paint I just feel better, even though its not really necessary..
i would like to hear how you like that gun when you are finished its what i've been looking at, because my old gun is gone and i'm down to just a small little old school siphon gun |
I just got done doing a '66 Chevy II in Marina Blue (Lt blue poly) and it was a bear cat to get... hardest I've ever dealt with... but also did the job in Martin-Senour because the customer worked at NAPA, while I'm used to using PPG... long story short... once coverage was achieved, we nibbed the base with 1000g... then cut the base in half with blender, over reduced 10-20%, turned the air pressure WAY down to control, talking 15psi, increased gun distance, moved F A S T and overlapped 80%, then immediately cross coated the panel while maintaining a medium coat... never had such problems with a color. As hard as it was, the loss column remains empty
| grabber blue same as petty blue? | dual4 | Body - Exterior | 6 | 04-13-2010 06:55 AM |
| 1939 Mercury blue poly | drchip | Body - Exterior | 0 | 01-28-2010 08:58 AM |
| Where are My Poly 318 Experts, need some help | SPARTANENGINEER1701 | Hotrodding Basics | 7 | 12-11-2009 02:26 PM |
| blue poly foam for headliner idea | merowe | Interior | 4 | 09-01-2003 08:44 AM |
