lt1
how much hp does a carb lt1 engine have
lt1
It came from a 1995 impale it has a 750 edelbrock and Holley intake on it
lt1
Okay what can I go with to reach 400hp with the setup I have now and what transmission to
10208890 is L99 at 4.3 liters of V8 not V6 10125327 is 5.7 liters of LT1 Bogie |
yeap ive seen a lot of people that get tooken for the 4.3 and tear it down and be pissed cause its not the 5.7 lol,the 96 lt1s have knock sensors so that a lil info
Not overly familiar with the LT engines, but I would guess you will have to do a bit more massaging to get 400 hp out of it. Nitrous will get you there quick if you dont need it all the time and are willing to "cheat." I'm sure others will chime in with other ways to reach your goal. |
Head work cc503 Cam 1.6 RR Headers I think this will put you very close to your goal. |
400 hp, where at the fly? Building "the less popular" GM efi engines is what I do. and 400 fwhp is easily achievable without doing any head/intake porting and certainly no aftermarket heads either. Basic bolt ons like headers, 52mm throttle body, cold air intake, and a good tune have yeilded results for several ltx f body guys of 375 fwhp, b body would be harder as header selection is limited to upswept mid's from what I seen without shelling out MEGA bucks. But with the right combo you could get 330-350, then pick out the right cam and again the right tune, and you could exceed your goal of 400 hp.
400 rear wheel is another story, my ported heads/intake 383 GM847 cam true dual x pipe car does over 400 rwhp/400 rwtq, but it was a lot more work... But I would say the guys I know who have swapped to carb said it wasn't worth the hassle or expense. You probably got the engine with intake manifold(if not they are very cheap used $50) where as finding a used carb LTx manifold if you can will run $200($300 new). If the intake was on it, injectors and fuel rail may have been as well. If not again they are cheap used and in good working condition(less than $100 for all). I will be hard to find a good carb setup for the same price, unless you already have the right carb. Not trying to talk you out of it at all, just trying to give you some thing to think about if you hadn't. Hope this helps, Josh |
What about if I port the heads and get a lt4 hot cam kit
will this help with reaching my 400 goal |
From what Texas97z said you may not have to port the heads. He says he builds the LT1 engines so he should know better how to reach your goal. The question is: 400 flywheel hp or 400 rwhp?
These engines are considerably more expensive than a old LT1 though. For which reason people choose the LS BASED GenIII/IV truck engines. The G-III 5.3 truck engine puts out more than an LT1 and can be had for around 700 intake to oil pan in running condition. Most all of the parts between the LS series engines will swap over to the truck engine. Finding headers for a GIII/IV or LS type engine is a whole different story, usually rangine upwards of $600 for a set of long tubes. |
| LT1 Block | rwc112 | Engine | 8 | 08-04-2009 03:47 AM |
| Lt1 heads on vortec block | Ugly89Camaro | Engine | 3 | 01-14-2008 09:53 PM |
| LT1 headers...fit other heads? | Speedyoldtruckdotcom | Engine | 2 | 06-25-2007 10:00 AM |
| lt1 cop car | Brian Morency | Engine | 27 | 08-24-2006 03:38 PM |
| 94 Camaro lt1 Vs. 95 Camaro lt1 | NEEDHELP | Engine | 3 | 11-05-2002 11:45 AM |
