Lt1 6 Speed In A 66 Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 08:40 AM
I Am About To Install A Lt1 6 Speed In A 1966 Nova. Has Anyone Done This ,Or Know Anyone Who Has For Problems Or Solutions
Old 11-11-2006, 09:22 AM
Original V8 equipped Novas with a manual shift transmission has a special V8 block ... with a raised oil filter location and a unique place on the side of the block for the clutch linkerage to attach.
They also had a smaller bell housing
I believe you will have to do a LOT of fabricating ... to do install the newer style LT1 and the 6 speed. The 6 speed is considerably larger than a Muncie 4 speed. I would most likely plan on buying a new front clip for the Nova ... This would allow for the coil/shock towers to be removed.
Lots better suspension, rack & pinion steering and disc brakes ... along with room for everything.
Old 11-11-2006, 09:41 AM
redlightning's Avatar
Sorry,I had to edit this.I had a link to a 70.
Great info Deuce,I didn,t know there was a different block.
Old 11-11-2006, 09:54 AM
Yes ... the block was different. The oil filter was raised for clearance. In fact, the V8 Nova blocks had a spin on filter ... before the rest of the V8 small blocks did.
I have been told ... that the LT1 new style blocks have a different motor mount position than the old standard 58 up conventional SBC we all have grown used to.
I do not have PROOF of that ... but have heard it from different sources.
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 50 10-20-2009 06:04 PM
leaf springs for a 66 nova.... sc2dave Suspension - Brakes - Steering 12 12-29-2006 10:51 PM
paint ideas for four door 66 nova 2 merowe Body - Exterior 2 01-30-2006 12:47 AM
66 nova ignition lock ring.... sc2dave Electrical 2 04-24-2005 09:51 PM
66 Nova Chevelle Malibu brainsboy Hotrodding Basics 5 03-18-2005 06:52 AM
