LT1 94 no power - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2006, 11:38 AM
weedhopper's Avatar
LT1 94 no power
i have a 94 z28 LT1 loss of power gets much worse as temp goes up no check eng light i took to gm garage they said was bad computer wrong still does after changing. fuel pressure is a lil over 40 book says thats where should be wont pull itself up a hill gets a ping knock sound any good lt1 peps with any ideas ? thanks
Old 07-22-2006, 02:11 PM
DoubleVision's Avatar
when was the last time it was tuned up?
Old 07-22-2006, 02:42 PM
weedhopper's Avatar
wires are a lil over a year plugs about same it has optispark dist so the cap and rotor id say are very old at guess. car has 110k miles its a bear to get to cap waterpump has to be off to get to it before going that far i wanted check any known things parts store said cap is all solid state seald and at 160 bucks just for cap and rotor pretty expensive trial and errror
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 11:45 AM
