LT1 with a Carburetor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2002, 10:56 AM
Question LT1 with a Carburetor
I'm building an LT1 on which I will use the GM manifold that permits use of a carb and conventional distributor. Anyone had any experience converting from the TPI and Optispark computer controlled OEM configuration? Assuming stock compression, how difficult will it be to avoid detonation without the knock sensor/ computer-controlled antiknock subsystem?
Old 12-11-2002, 01:35 PM
deuce_454's Avatar
Post
not at all, but you are going to run into problems with the distributor, the distributor is mounted in front of the cam cover. In my wiew you should get a HPX3 ignition system from electromotive and do away with all the distributor related problems (recurving etc.)once and for all
i asume you are refering to the post 93 corvette LT1 with reverse cooling?
Old 12-12-2002, 05:06 PM
Post
Thanks for the response. My buildable core is from a post '93. The GM manifold comes with the standard rear-mount distributor hole if you want to go with a standard distributor in place of the front mount Optispark or similar aftermarket type. You also get a plug with the manifold to cap the hole if you stay with the computer controlled front mount ignition.
