LT1 code 11 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 09:18 AM
goldenrog
LT1 code 11
I put a 94 LT1 in my 51 Pontiac. I'm fighting with a code 11 (CEL circuit) I used an LED for the CEL then I added a relay across the circuit thinking that the PCM wasn't seeing enough voltage drop across the LED. I'm still getting a code 11 which stops closed loop.
My tuner program doesn't give me the option of disabling this code. Any suggestions?
Old 05-05-2006, 10:05 PM
goldenrog
problem solved
Got no replies on this one. I did some more diagnostics and found no power on the CEL circuit at the PCM. Double checked the wiring diagram and low and behold, I tapped into the wrong wire in the harness. All is good, it goes into closed loop and makes great power! Special thanks to Tuner Cat for their help and a great tuning program!!
Old 05-06-2006, 05:11 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Sorry no one was able to help you with your problem here..
But I'm glad to hear that you got it fixed!
Thanks for posting back with the fix , it may help someone in the future!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
1970 Camaro LT1 value? Steve-0321 Hotrodding Basics 2 05-17-2005 05:04 PM
Code has me Stumped 8.5" 10 Bolt Posi Ghetto Jet Transmission - Rearend 1 03-13-2004 04:50 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 12:45 PM
Need LT1, or LS1 Sycotic Engine 0 09-17-2002 08:36 PM
