LT1 head to vortec head - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2008, 07:50 PM
46 chevy pickup's Avatar
46 chevy pickup
Hi Guys;
The intake bolt patten on the vortec head compared to LT1 head
Thanks Bobby
Old 08-28-2008, 08:13 PM
Originally Posted by 46 chevy pickup
Hi Guys;
Thanks Bobby
Which LT1 head and which bolt pattern. The LT1 head whether the 1970s version or the 1990s version is same as all small blocks for head to block. Intakes are all different old LT1 to newer LT1 and both to Vortec.
The newer LT1's end coolant and oil return passeges do not match with non 1990s LT1 or LT4 blocks without some welding and machining on the head.
Bogie
Old 08-29-2008, 09:12 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Not to mention iron LT1 heads are the same port as vortecs, so no benefits if that's what you were looking for. As far as intake bolt patterns? Totally different. Compare these two gaskets:
http://www.jegs.com/images/photos/80...9-89017465.jpg
http://www.jegs.com/images/photos/720135G.jpg
Notice one has water passages and the other doesn't. One has exhaust crossovers and the other doesn't. The bolt pattern is also wider on the LT1
Its been done, but its not worth it for all the work and trouble
Old 08-30-2008, 07:58 AM
46 chevy pickup
LT1 to vortec head
THanks for the reply guys;
The reason for ? is I have complete intake,computer,wiring from 1994 trans am.
I'm going to modify for dist, bolt holes and install on 1st gen sbc.
I know 1st gen intake has more holes at angle.
The vortec heads have straight intake holes.
Though it may be better to modify intake holes for vortec than 1st gen heads.
Thanks Bobby
Old 08-30-2008, 08:27 AM
RippinRon's Avatar
The vortec ports don't come close to lining up.
ports
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
best plugs for a vortec head? runn141 Engine 6 09-05-2008 03:15 PM
Vortec head quetions,, tiresmoke55 Engine 3 04-24-2007 10:47 AM
Lt1 intake for vortec heads? Newt408 Engine 1 12-06-2003 11:33 PM
Will vortec exhaust manifolds fit an LT1? kevmor99 Engine 1 10-21-2002 07:15 PM
