LT1 Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2005, 12:14 PM
LT1 Heads
Hey guys this may sound like a stupid question but i was curious if anyone has heard of putting lt1 heads on first gen small blocks?
Old 06-02-2005, 01:57 PM
Mr Ed's Avatar
there are iron and alloy LT1 heads and as the engine was redisigned with a different coolant direction i don't think they will work although i think the head bolts will line up
Old 06-02-2005, 02:43 PM
King of my Man-cave.
The LT-1 heads are similar in design to the Vor-tec heads. There were 2 aluminum designs and 1 design of the cast iron heads (2 casting numbers). The iron heads have better flow numbers than the aluminum heads.
They can be used on Gen 1 blocks, but you must use Gen 1 head gaskets and plug the holes in the end of the LT1 heads. The chambers measure around 58ccs.
Do not use the "Baby LT1 (265 cu inches) heads. Chambers are WAY too small.
tom
Old 06-02-2005, 03:34 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
tom
I have never heard of these, more info please.
It is true that the coolant flows through the heads then the block with the LT1 over the 1stgens, but I dont know if it's that big of a difference other than what Tom said in his post above.
Old 06-02-2005, 04:47 PM
GoneNova/406's Avatar
1st & 2nd generation LT1 heads are regular hi perf. chevy heads.the 3rd & 4th generations are the reverse flow.
Old 06-02-2005, 08:40 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
A friend who is a tech at a GM dealership, attemped to use the alum. LT1 heads on a 1st gen 350. He went to alot of effort, plugging the coolant ports on the ends, grinding the coolant passagess in the deck of the heads to match the head, etc. to make them work with the standard cooling system of the 1st gen After approx. 20 hrs of labor, the engine still ran hot and was prone to overheating. He gave up and just went with the Vortec heads.
Old 06-02-2005, 08:58 PM
Bumpstick's Avatar
Hammer and a torch
Can we say "Alcohol"...? but might need a big tank...
Old 06-02-2005, 09:16 PM
well i heard of a guy doing it and he said he ran coolant lines coming out of the back of both heads to the top port on the water pump.this make any sense?
Old 06-02-2005, 09:35 PM
topfuel's Avatar
It seems to be more work than it's worth in my opinion. Start with matching components instead of adapting parts that weren't designed to work together.
Old 06-02-2005, 10:17 PM
Absolutely just wondering if it could be done kinda like stuffing a ford 9" in your chevy vega with the over size 454
Old 06-02-2005, 11:40 PM
if you look at jegs site you'll see those lines in the cooling section.they normally run from water pump to the plug in the side of the heads there by getting cooler water to the heads.this is on a regular system.i don't know about yours.
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
1995 Lt1 350 Heads ambrosemii Engine 1 05-07-2003 03:30 PM
LT1 Heads on Older Block? Hammar Engine 9 04-24-2003 10:23 AM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
