LT1 intake Conversion
Hey guys I am in the process of learning how to modify an lt1 intake to fit onto a Gen 1 sbc. So far I have milled off the egr housing and redrilled the holes that go into the heads. I still have to drill and tap coolant nipples and cut the hole for the distributor. Heres some pics so far....
![]() ![]() I figured to cut the distributor hole i will just make a jig that holds the intake and put one that already has the distributor hole cut in the jig and measure where it sits then swap it out for the lt1 and cut. I have a couple questions on the distributor shim that is needed. I have found a couple threads that are over 5-10 years old that had the names of some people who were selling them but are no longer. Can anyone give me the dimensions or possibly a source to buy the shim. Thanks for all your help. |
Man i just love hotrodding.Keep us posted. Cole |
I have very little money to go spend on an aftermarket intake. I picked this up at my local upull for i think like $27.18....or something like that. Plus anyone can go buy an aftermarket intake. |
Looking good! Aren't the ports going to be pretty badly mismatched? LT1 intakes' ports are more like Vortec ports. Wont you have un-gasketed port sections?
I like this guy... taking what he has and experimenting. That's hotrodding. If it doesn't fit, put it on a bridgeport until it does
I like the idea of just doing wasted spark instead of having to worry about drilling the hole for the distributor in the correct location and make sure i get the height and angle correct. Would I just setup a crank trigger setup? http://www.theherd.com/articles/lt1_cool.html This has a great article on the benefits of the lt1s reverse flow cooling. |
okay ive been thinking about this a lot the past couple days. it will probably be a lot of work but i think it will be cool when i get it running and i am sure i will learn a lot in the process. this is what I am thinking. I will use the shaft that is in the lt1 to drive the oil pump
![]() and i will machine the block to allow me to bolt it into place.. ![]() I can then use the vortec front timing cover with the crank position sensor on it to trigger the ignition. ![]() I guess this would be a DIS ignition setup with wasted spark because i will be firing off the crank which will spin twice for every combustion cycle. What do you guys think??? |
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| LT1 Question | DV8 | Engine | 10 | 01-07-2007 11:59 PM |
| Head recommendation - low HP w/LT1 intake | Tim240Z | Engine | 0 | 07-08-2004 12:56 PM |
| dual plane intake efi conversion | macx | Engine | 0 | 10-29-2003 06:41 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
