LT1 into a 64 Belair - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2006, 04:16 PM
STRCOMP's Avatar
Fun Seeker
Does someone know if I can use the stock harness and computer in this swap? The engine is out of a 95 Cadilac Fleetwood Broughm. It has a 4L60E trans.
Maybe it's not worth messing with and I should go to a Painless harness & computer.
Thanks.
Old 01-09-2006, 04:36 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Yes you can, but you will need to modify it and have the computer programed for no theft deterrent. The painless harness is the way to go if you are not good with wire schematics.
Steve
Old 01-09-2006, 05:22 PM
STRCOMP's Avatar
Fun Seeker
We did put a 305 Tunnel Port into a 53 Chevy pick-up using the stock harness. It did take some time to sort out all the codes and weed out all the wires not needed.
It seems this project would be the same.
lt1 cop car Brian Morency Engine 27 08-24-2006 04:38 PM
1970 Camaro LT1 value? Steve-0321 Hotrodding Basics 2 05-17-2005 05:04 PM
54 belair rearend replacement ironhead54 Transmission - Rearend 1 04-10-2003 07:25 PM
94 Camaro lt1 Vs. 95 Camaro lt1 NEEDHELP Engine 3 11-05-2002 12:45 PM
Need LT1, or LS1 Sycotic Engine 0 09-17-2002 08:36 PM
