LT1 oil drive in a Big Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 05:52 PM
KA67_72's Avatar
I'm running a distributorless setup on my hot rod. If I make a boss to mount it to, and bolt that into the lifter valley, can I use a oil pump drive from an LT1 in a big block? Otherwise, what are some donors for the longer version used on the distributorless motors? I'm starting on my intake and would like to leave out the distributor hole.
Thanks,
Kevin
Old 07-13-2008, 12:48 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
It should work with a custom boss, but how will you make a boss on csst iron?
Old 07-13-2008, 07:54 AM
KA67_72's Avatar
I don't have an LT1 drive to check with, but I figured I'd make the boss out of steel, and drill and tap the valley. Then I'd bolt the boss in using Loctite, and a lock tab or safety wire.
Kevin
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
